EASLOOP
Thanks for the boom response so far - give me something to think about. But while that is going on perhaps someone out there has expertise in engine controls. I have a single lever teleflex (labelled Volvo). When going from neutral to astern the system slips into gear and the throttle takes over - smashing. however, when going ahead from neutral the first part of the travel seems to jam, the shoulder of the cable is pulled almost through the collar before the gear is engaged then it operates smothly. If I clamp the cable so it cannot try to slip through the collar it takes a mighty force to change gear to the point of almost bending the mounting plate. Thereafter it is stiff but will work.
Does this make any sense?
I would appreciate some input on this
Thank you
Thank you
