Technodrive TMC40 Can you make it rotate anticlockwise?
rich201283
10 May 2006
From what i unterstand my prop turns anti clockwise but the new box turns clockwise, Can the Tmc40 be made to rotate anti clockwise?
The PRM 150 will work happily in either direction.
I had the same problem when repowering. Owing to the offset P bracket and engine mounts I simply had to have a left handed prop. All the new engine and mechanical gearbox combos offered right handed ones. The hydraulic PRM was the answer.
We are buying the perkins m30 but need a lefthand rotatinon box. What ratio would the prm 150 be, Is there any other box's
Why do you need a left hand prop? Only reason is if it is offset. If it is a normal centreline prop it does not matter which way it goes, just your propwalk will be different. Unless you are replacing a similar engine gearbox combination you will almost certainly need a new prop so get one to suit your new installation.
