simonfraser
i'd def use a plastic bottle, you would not want to fall over whilst using a glass one OUCH !
I use an empty 2 litre milk bottle (plastic) with the top cut off but keeping the handle intact. Works a treat in all weathers and just needs to be swilled out.
SB
Very serious now! having just had my prostate "fried" by radiotherapy, I find it difficult to pee sitting down, apparantly to do with the fact that scar tissue affects the urethra. Standing up the tube falls naturally straight down from the bladder, thru the prostate and then down again to the exit. When you sit or kneel the urethra is bent and in my case makes it difficult to empty the bladder. I suspect a similar situation is happening here, bent urethra BUT also, is this signs of prostate trouble?, as I headed my previous post if you are of a certain age DONT DIE OF EMBARRASSMENT. If you are mid 50s on, go and see a GP!On some boats I have been on recently, males have been asked to kneel down in front of the loo when having a pee (to avoid splashing the woodwork I suppose).
I find it a bit difficult to empty my bladder this way so need a return visit shortly afterwards. Therefore I have been thinking that there may be a technical reason for it.
Choosing my words carefully. When a male stands up to have a pee the longer unbroken stream must have a greater weight than when he kneels down and issues a shorter stream. Does this greater weight have a syphon type effect that drags out the pee more efficiently.
To extend the discussion. If that is true, then on a calm day, if a chap has a pee off a cliff, could the extra weight pull him off the cliff?
This is not a troll. I am genuinely interested in why the kneeling in front of the loo causes me a problem.
How about peeing while standing into an empty 2 pint milk bottle then empty out of a scuttle.
No but if you believe this thread http://www.ybw.com/forums/showthread.php?t=208514 then other things could topple some forumitews over the cliff.To extend the discussion. If that is true, then on a calm day, if a chap has a pee off a cliff, could the extra weight pull him off the cliff?
It is usually best to pee in the hand basin.
Stand and Pee Hanging in the shrouds, but some may remember the old RNLI report about the DOWF syndrome which they encountered now and then during rescue missions searching for yachtsmen. Apparently all too often the recovered body displays the characteristic of DOWF (dick out when found)
Easier just to sit on the bog maybe?
