Anyone know of a UK source for Teak Veneer - not teak faced ply, just the veneer.
"Artificial intelligence is no match for natural stupidity" sailroom <span style="color:red">The place to auction your previously loved boatie bits</span>
Yes Cliff, Robbins is pretty good. They will also sell you (or at least used to stock) rolls of "iron on" glue. Iron on to one side of veneer, peel backing and iron on veneer to surface. Works a treat but you need to practice and dont get the iron too hot or the veneer will shrink and crack.
I don't need an 8' X 4' sheet but I'll give them a call - maybe they do smaller sheets or even off-cuts.
Cheers lads - I had forgotten about Robbins.
It doesn't come in 8x4 sheets anyway Cliff. (Trees aren't that wide /forums/images/graemlins/smirk.gif)
It will come rolled up in widths of about 18 inches usually about 6 ft long.
I am sure the glue sheet can be bought in small quantities but if you can't get it PM me, I might still have a roll in the loft...... (Solent area)
[/ QUOTE ]I was looking at FLEXIBLE VENEER SHEETS
An exciting range of high quality Crown Cut Veneers
on a flexible backing sheet. Ideal for re-facing both
flat and curved surfaces
2440 x 1220 x 0.5mm White Ash Flexible Veneer £45.35
2440 x 1220 x 0.5mm Steamed Beech Flexible Veneer £45.35
2440 x 1220 x 0.5mm Red Oak Flexible Veneer £45.35
2440 x 1220 x 0.5mm White Oak Flexible Veneer £45.35
2440 x 1220 x 0.5mm Cherry Flexible Veneer £49.45
2440 x 1220 x 0.5mm Maple Flexible Veneer £49.45
2440 x 1220 x 0.5mm Am. Black Walnut Flexible Veneer £66.95
2440 x 1220 x 0.5mm Pine Flexible Veneer £36.05
2440 x 1220 x 0.5mm Sapele Flexible Veneer £36.05
2440 x 1220 x 1.5mm Teak Flexible Bending Plywood £98.53
[/ QUOTE ]Seems these are a new product for Robbins and come in 8' X 4' sheets.
OK yes I see! This is indeed new and will hopefully get over the problem of applying heat. At that thickness you might be better off using contact adhesive, especially if you can use the 1.5mm. I would however ask how thick the veneer itself is though as you will still need to sand it lightly for a good finish.....
If its only a small bit you need though iron on veneer will be cheaper.
