LittleShip
And don't try fixing bungs with varnish, that's old ways and not suitable for exterior fixing when there are several much better products.
I use epoxy to refit mine.
Tom
Tom
Tom
I can't visualise this working - the forstner bit drills a flat-bottomed hole, so it won't get below the top of the screwhead.
I agree that you want to avoid collateral damage to the screwheads but it sounds as if his screwheads are knackered already having tried to drill them out.
Because the bit is guided by the circular rim as opposed to the centre. A Lip and Spur drill bit (as an example) will merely drill on to the screw head. If he uses a bit of, say, 10mm where his original plug is 8mm he will drill a 10mm hole thus giving more space to work on removing the old screw. He then fills with a 10mm plug.
The bit, in effect, acts a little like as plug cutter but not nearly as aggressive.
The Forstner bit will, eventually, lose it's pointed centre but that actually aids the process and, for a few quid to replace, makes little difference.
He could also, if he wishes, nip and blunt the centre of the bit.
