FairweatherDave
I have a very slight leak through one fixing point on the teak coaming over the coach roof of my Konsort. So water is making its way under the wood and then through the roof, and then a slight drip through the hole in the grp exposed by the headlinings being down. I do not want to disturb the whole coaming but obviously I want to stop the water entering and making the balsa core a mush, as well as damaging the headlining underneath.From above my plan is to scrape away all the old sealant along the base of the coaming and hope the teak is solid enough to be resealed with sikaflex. But what about the hole through the roof, which I guess had a dowl plug that is no longer doing anything. Do I drill out a bigger hole from underneath and epoxy in a bigger plug? Any advice would be welcome, I do use the Westerly forum but this is suitable for a wider audience of PBO. I would add I am not too worried about the balsa core, providing I stop the water getting into the void now. So I want to reseal the whole coaming without moving it. Is that practical? Thanks for any polite advice on this can of worms!
