Targa 52 anchor windlass
itspaul
19 Jun 2010
Home staffs Boat Mallorca
Hi all as the per the title the anchor windlass is not working the telltale on the control panel is alight but nothing is working from either the foot switches or the switch at the helm I have checked the breakers in the rear cabin but nothing tripped. Is there another trip or breaker somewhere I'm missing ? Thanks.
i have the same boat and the same problem.
In the engine room there is a metre wide metal panel marked "12v/24v system". Unscrew the plastic retaining screws and remove the panel. You will see regular breakers on the left side for things like bilge pumps etc. I the middle will be 8 or so heavy duty breakers. One is the anchor windlass - it should he labelled. If memory serves, on my Targa 52 it's the third one along.
on the bottom edge of the breaker, there is a tiny switch. Hard to see, so I reset mine by feel. Again, if memory serves, I think you flick the switch toward you.
Sorry I can't be more helpful - away from boat so hard to direct you with more precision
Good luck
