prv
For what it's worth I have a cleat attached to my mast with two M6 (I think) machine screws into threads tapped in the ally. No sign of movement yet.
Thanks for all the replies. Now that you remind me I have seen rivnuts mentioned here before. For the amount of work that I might do, I thought I was doing well equipping myself with a pop rivet gun and a tap and die set. Now it's suggested I use something else (imagine one of those non-smiley faces here).
I've edited my original draft because I didn't quite appreciate how rivnuts work.
Rivnuts seem harder to find (they don't come up on the Screwfix website). Where could I at a reasonable price equip myself with a rivnut installation tool and selection of rivnuts?
mast are thin and for that I would not tap it
us a PK type screw, old name I have in my head also known as a self tapper screw , you drill hole so the screw is tight to screw in and you can get blunt ones
if you want to use rivet nuts you dont have to use a tool for a a one or two off
drill hole put in rivet
use a bolt about twice as long as the tread and wind a nut up it most of the way
then put on two smooth washers dipped in oil
then wind it into rivet all the way
holding the head of the bolt still with a spanner do up the nut towards rivet and you will fell it stating to pull it up when you think it has pullrd up unwind nut and remove your bolt
You have to make do with what you have.With the question on tap and die sizes reveals lack of familiarity with the process please note that for any size thread there are "specific" size drill bits that should be used. Most standard size drill bits eg in 1/32 or 05mm increments will be approximate and take out too much material.
I remember getting a normal rivet gun with an adapter to pull up Rivnuts. Basicly a sort of pop rivet with an internal thread. But they do have lumps to prevent them turning and should have notches in the sheet to engage those lumps, so not quite the simple hole that a pop rivet normally goes in.
I did spend some time up a mast using a big riviter to pull some 6mm Monal ones... not fun.
