sailorbenji
Hi all,
Something I've been meaning to do for the longest time is fit float switches to our forward water tank, for our water maker. This would allow us to leave it on maintenance mode, where it would use water to flush itself through, and then refill the tank.
The items provided to do this are two physical float switches that I would need to fit to the side of the tank, top and bottom. Access to the tank is a nightmare, in fact I can't see how I could drill the appropriate holes without dismantling most of the saloon, and this got me wondering......
With cheap boards like Arduinos and Pis being so prevalent, would it be feasible for such a device to read the resistance level from our existing analogue level gauge, then for it to create voltage free switch contacts when it detects the resistance levels are at full and empty?
I know there are a few amateur electronics gurus around these parts, and keen to get thoughts before I embark on the path further (I'm far from a programmer!).
Thanks, Ben
Thanks, Ben
