FatherTed
Active Member
7805 voltage regulator, will accept up to 25v and convert to 5v.
Hi, any updates? did the sensor work?Thanks all. Have ordered a boost sensor, just got to wait until it's delivered (from China). Will update when I have more news.
Did this actually work? even though the sensor isnt the same as the one replaced?hello I'm from Brazil and I recently had a problem with my ecu on my tamd73 pa and the mechanic made me buy a new ecu $5,000 here in Brazil I took the old ecu and started digging the gel and ripped the sensor to pieces and it I didn't have any code recorded but later I realized that the code had been transferred to the gel the model and (SMI5502-100 A) after a lot of research I found its datasheet and found that it is no longer available on the market but I managed to get it to work and a replacement sensor that can be easily found on the market at a low cost. the original sensor has 6 pins but only 3 are used for the working image of the sensor and 0-100psi and 1-5 volts. I did the Chinese sensor replacement and it worked perfectly. the gel can be easily removed with a soldering iron. I have no experience with electronics I am curious but the work was great, perfect working tested and approved. If you need I can give more details on how to do it. sorry for my writing I'm using a translator.View attachment 141269View attachment 141267View attachment 141266View attachment 141268
