Bojangles
Looking for advise, my port engine has been ejecting coolant through the tube at the filler cap, into the bilges. This engine has been running at a slightly higher temp than the other side. When I remove the filler cap the coolant is about half an inch from the top.
I recently had a broken shaft coupling on this side and discovered there was an alignment problem. The shaft has currently been removed for staightening.
Are these issues connected?
