kashurst
fingers crossed for you
I hope you have found the problem. An old trick that only ever works for a few days on compressor oil pumps to attempt to deny the real problem of serious bearing wear issues is to stretch the spring, which does work for a short while, until the spring does what springs do and returns to its original shape and form.Found the pressure relief valve and removed it to find that was not seating correctly and was a gap where it seals so a new one is on its way and have a good feeling that this has been the problem all along as the previous thread back in 2012 said it had been replaced, but I can tell you this much it has never been replaced so it's best to check everything rather than reading about what previous owners have supposed to have done
