paradave
By decrub I meant a jet wash/scrub!
I have exactly the same issue which I feel (and the surveyor feels) is NOT normal. I bought my 805 in August and did delivery passage over 7 hours at under 13knots due to heavy weather. The sea trial showed some smoke at start up but nothing apparent once warm and the surveyor checked all the temperatures and readings. All seemed ok.
As we approached the end of our delivery passage turning from a beam sea to a following sea I noticed lots of steam and stopped. We had. not seen steam in the previous several hours. The temperature was not high - 80-85 range and we had not pushed it at all as it was rough. I motored gently into our home mooring.
The next outing was to move the boat to a winter mooring about 2 hours passage. The steam appeared again and I was not doing over 12knots. The engine temperature was slightly high. When I tried to increase revs the engine faltered and would not increase revs over 3000 and we were doing no more than 12/13 knots! I throttleed back and the temperature dropped back to 75/80. I then decided something needed doing via an expert.
I have checked and replaced the fuel filters. Pre filter was brown and secondary filter was clean. The raw water filter was checked and this was clear. The oil was higher then full by 1/2" on the dipstick which may cause some of the oil smoke I get at idle. I have replaced the water pump now but not had chance to test run.
If he’s getting 12kn @ 3100 sounds like the engine is trying, what does yours do at 3100? As the op can’t be sure he’s had more speed could he have the wrong pitched prop?Have you checked the turbo is spinning if you have lack of revs
Do you actually know it’s overheating? You said that the temp quickly dropped when you throttled back, could this just have been the thermostat opening? Is 3100 rpm wide open throttle?The oil was changed along with filter. I don't have lack of revs I have lack of speed.
The boat seemed fine when it was trialled (surveyor on board taking readings/temperatures with laser thermometer) and for the early part of delivery trip a week later. The problem manifested itself during the delivery trip.
I was told today at the marina that it was definitely head gasket from a layman sailor because of the overheating. But if it was overheating to only 90c that would not stop it hitting 18 knots+ at 3000 revs? I would lose water and eventually the engine would suffer from extreme overheating? I have never let it go over 90c for more than a few seconds before throttling back. During the delivery trip it never got hot as we were doing 12/13 knots so why would head gasket go under those unstressed conditions?
So he’s not far off speedwise then. Mine tops out at 3500, ~22kn. Wot should be 3800 but full tanks probably knock ~200 off.At 3100 revs mine does about 12 -14 knots and at 3600 its hitting 17-18 knots but mine will hit 4100 but this is over reving so i only take it to 3800 .
I used have a Nannie 4.90tdi in a sea ray 240 .Max revs are 3600 for Nanni 200HP. I can push throttle all the way and nothing happens for the last bit it does not go to 3600 and does not go over 12 knots. The temperature does rise and the thermostat officially opens at 75c. (sorry it's 71c) Taking it too hot will cause damage which I am trying to avoid.
We know this problem was there last year so any growth will not be the reason as it was cleaned and checked before delivery. The fuel tank is 1/3 full. 2 people on board.
Reading through Hilux forums which have the same engine points to head gasket as a regular failure but I have not overheated the engine so unless it was cracked before I bought it the problem has occurred without any over stressing of the engine.
My confusion is is that IF the head is cracked would that prevent the engine getting to 3600 rpm within 1 mile of travel with temperature at 85-90c??
