bowler
Hello again,
Having made some progress on my rpm issue I am ready to move on to my last piece of pre season maintenance/upkeep (not including filters).
I am going to replace my engine mounts on my SB engine. It has a rock at idle and moves forward about an 1/3 of an inch when in when in gear at low rpm. I can also see some play in the mounts which the other engine does not demonstrate. They look like they may have been replaced at some point. Oddly enough, according to my feeler gauges the alignment is ok on this engine but never the less they have to go. The vibration is giving me some shaft seal drips but the shaft is centred in the log at rest. I have ordered R&D mountings based on some internet research for other TAMD41s with the ms4 gear box, part numbers 800-004 and 800-005. I plan to do one corner at a time, jack it up, swap them out and move on. After disconnecting the shaft coupling of course. Then realignment and hey presto. Then check alignment after a few hrs as well?
The top bolts were pretty tough to move but I have managed to get them turning after a good bit of pen fluid and brute force. Haven't had luck with the back two but haven't tried in anger yet.
Sounds too easy, although shifting the nuts is a different story.
Am I missing anything? What about bolts for the bearers - anything in particular beyond stainless?
Thanks in advance,
D.
Thanks in advance,
D.
