superheat6k
On my TAMD60C there was a small bleed screw on the banjo onto the turbo to allow bleeding. Crack it open until you get a smooth flow with the engine running at fast tickover.Gents,
Apologies for the late reply.
Thanks to all for your contributions. Its certainly given me a direction to work towards. As regards venting the turbo cooling I was given to understand that after draining, partially refill the header tank and start the engine, add more coolant to the required amount (In this particular case 11 litres) and leave header tank cap off. Is this correct, or is there an alternative method for doing this as I have downloaded the owners manual and the engine manual from the VP website and neither of these make it very clear how to perform this, other than the 'venting' aspect
