simonjames
Hoping for some help please. We have a Fairline Targa 43 with TAMD 75 EDC engines. Doing some boat handling basics ie astern, forward tight turns etc boat was fine. Then suddenly everytime you put the port engine into astern, the boat totally lost drive on the port engine, it didn't go into limp home mode just sat ticking over and wouldn't select forward or astern until turned off and re started. Took the boat back to marina on starboard engine, an engineer came and diagnosed it as the solenoid replaced it and the engine instantly selected forward and astern on port engine. However, the starboard engine then decides to enter limp home mode. Engineer arrives and diagnoses potentiometer fault, brings a spare new potentiometer and boat seems ok. Going out to do some more boat handling starboard engine drops out into limp home mode again, back to berth again on Port engine this time. Engineer duly arrives starts boat everything ok, advice of the engineer turn engine batteries off for 12 or so hours and fault would clear. He duly arrived next day turned the batteries on and declared the boat repaired. Later in the afternoon started up the engines removed the springs and the boat selected forward gear on starboard engine on its own while ticking over in neutral according to the controls. Engineer comes back and removes a very hot grey relay, changes it and no difference at all. Does anybody have any ideas as this is wrecking confidence of the boat to the point where my parents are really regretting buying it. Sorry the post is so long just wanted to get all the facts out.
Thanks in anticipation
