John100156
I am confused.
1800rpm would mean my Sealine F44 is doing about 14 knots (guesstimate) which is right in the hump, pushing lots of water. I would assume that an F43 will be much the same. That's not an economical place to be. I am sure I would use more fuel on a journey of say 20 miles at 1800rpm than I would at either 18 knots or 7 knots covering the same distance. LPH is not really relevant in my book as I don't care how much fuel is burned per hour. I am only interested in the amount of fuel used to cover a specific distance.
I was referring to the following table: reproduced from an actual MB+Y Boat Report in post #16, (similarish size boat, same engines) you will see that the boat on test actually achieved 16.1 Knots (so over the hump pushing less water) at 1800RPM burning 10.8GPH, they recorded 1.5MPG At other speeds the actual MPG recorded was worse.
Now if you upped your revs to say 2400RPM you would certainly get there quicker, but your MPG would be less, because the gallons used for the miles covered would not be per hour. We were of course talking cruising speed range here, not pootling speeds. If you Pootle, as we have already estabablished, greater economies can be had. I see cruising speeds at 'above the hump' RPM, do others?
I would be very interested to receive the speeds your boat achieves at the rev ranges I quoted earlier..... I hope to re-launch my F43 with new AF on 5 March, weather permitting I will take her out and I will record/post the results. Hope the OP doesn't mind us digressing... I think this link should be to the table:-.
http://www.ybw.com/forums/attachment.php?attachmentid=16129&d=1329056641
