Tachometer Lens
Ian_Rob
31 Jan 2008
The ‘glass’ on my rev counter has become very cloudy, much worse than it appears in this old photo. I understand that it can be removed and polished with Autosol. Does anybody happen to know how it comes off? Do I have to take the whole panel off or is it retained by the surrounding bezel that is just prised off?
wonkywinch
30 Jul 2018
Hamble, UK
Is it worth just polishing the outside first and see how it looks? Car headlights with plastic lenses go cloudy, yellowed & crazed but only ever need the outside polishing since you can't take them apart anyhow.
For cleaning up, I've used Novus plastic polish on headlights, light aircraft windows etc to good effect. It comes in 3 grades, worth buying the set.
lustyd
27 Jul 2010
Despite not the same instrument, the housing would be similar:
I did mine recently using that video and it was surprisingly different but similar in a lot of ways.
Mine had a metal bar holding it in at the rear, remove two thumb screws to remove the bar.
Next the unit twists (gently!) to remove. Doesn’t unscrew it’s a 1/4 turn if that. The bezel does push out forwards but may be attached to the plate with sealant.
Then remove the screws from rear of unit and the unit needs to turn to release. I’m not certain this is needed to remove the lens, but was for the lcd replacement.
rogerthebodger
3 Nov 2001
Even through it had Volvo Penta marking it will be a VDO manufacturer.
The bezel is removed by twisting it 90 degrees to the right and once removed the lense can be prised out from the front.
I have had several on my various boats
PaulRainbow
16 May 2016
Suffolk
If the bezel is metal, which it seems to be, it does not twist to remove. You have a job prising the metal bezels off and getting them back on without damaging them.
Ian_Rob
31 Jan 2008
All very useful background info. Thanks very much.
VDO tachs, if the same or compatible with the EVC that I have, appear to be very much cheaper than the prices I have seen for the Volvo part. I don’t need to replace the whole unit, just sort the lens, but good to know.
PaulRainbow
16 May 2016
Suffolk
EVC is irrelevant to the tacho. You don't have to stick with Volvo or VDO, for instance, KUS, an example here : KUS Tachometer Gauge Marine Boat Car Truck LCD Hourmeter RPM Gauge 4000RPM | eBay
rotrax
17 Dec 2010
South Oxon, Littlehampton and Wellington, NZ.
Many years ago I bought a fire damaged Honda motorbike. It was brand new but had suffered in a showroom fire.
The seat back, tank, fenders and sidepanels were re-painted, new footresr rubbers, cables and handlebar rubbers were fitted along with new handlebar switches which had melted.
The Speedo and Tacho lenses were U/S. The needles could not be seen through the sagging and melted lenses.
A helmet visor meant for a jet style helmet was used to make two new lenses. Lasted for years. At the time the visors were about two quid. New Speedo and Tacho about ninety.
No brainer.............................
lustyd
27 Jul 2010
They're all a bit different so please be careful giving such confident instructions as it encourages people to confidently follow them! I nearly broke mine following the above video assuming it was the same as mine (it looks identical in every way!)
rogerthebodger
3 Nov 2001
Cannot comment on your Tacho but looking the pic the OP posted it is Identical to my YDO tachos
The smiths tchos on all my classic cars are crimped so are quite different.
The bezel in the OP's pic show a round bezel that can be replaced with a square bezel
Twist off bezel
Weiterleitungshinweis
Crimped bezel
PaulRainbow
16 May 2016
Suffolk
Twist off bezel
Crimped bezel
I think you are mistaken Roger. The OP's bezel is not the same as the one in your first link, it is a metal bezel, which will not be removable how you describe.
Also, the plastic bezels that i have seen rotate anti-clockwise as viewed from the front. Your may differ, but i've not seen any that rotate clockwise to remove.
