Tacho reading high - VDO
Refueler
13 Sep 2008
Far away from hooray henrys
On my Penta AQ170 - there is a VDO RPM display on the console and I am sure it is reading high.
At idle - which I would expect to be about 700 - 800rpm ... its reading nearer 1200rpm ..
Question :
What would be usual idle RPM of a such a gasoline engine ... I assumed similar to the 164 Volvo Car its derived from ?
How to adjust the RPM reading ?
I have a hand held Tacho - so I can read the real RPM if calibration can be made ...
scottie
14 Nov 2001
scotland
Question :
The tacho needs to be set up initially
Check number of cylinders selected
It doesn’t actually use revs but sparks ⚡
Refueler
13 Sep 2008
Camera inside console ... and removed VP panel to see behind ...
The RPM display looks ancient and has quite a few wires to it .. but I cannot see any adjustor or switches etc. I am wondering whether it is a hang-over from when the boat had a 4cyl AQ130 ... she now has the AQ170 6 cyl engine.
If push comes to shove - I could always swap out to a sensor on outside of alternator driven system ... cheap enough and work well.
I will try and photo the back of the panel next time I'm fiddling about there.
