Seagreen
Here's the problem:
[image]
[/image]
First, the exhaust is very close to the waterline and doesn't have a swan-neck fitting - its impossible to fit one in the space. Second, the top of the syphon break is only just higher than the exhaust.
Normally, the exhaust and cooling water flows from the engine and out (green arrow), but the syphon break also has a valve at A, to divert the water out via another skin fitting.
My problem?
Does the valve at A have to divert all the water in the direction of the Red arrow, and shut off the rest of the syphon break tube, or does it just provide an alternative exit?
I'm very confused as to what the vale should shut off, if anything. Answers please. TIA
[image]
My problem?
