Ecosse120
Finally got my electric keel winch up and working and then I started to put the switch gear behind my nice new woodwork so you had one push switch for up and the other for down. Umm well when the cables started getting warm and the switch started smoking I though that I may have got it wrong !! There is about 70amp running in the cable !!
The switch is in two parts and I believe that when I put them together the gap is too small and this is causing the problem. I guess my two options are either new switches that will take 70amp or fitting a relay. Please can i have views and any advice on what the wiring diagram should look like and where to buy switches that can take 70amp. As always look forward to getting some good advice. Thanks
