webcraft
Boat (2.5 tons, fairly low windage) is currently sitting on a professionally laid swinging mooring w. chain riser and (I estimate) 22mm nylon line to foredeck cleat led through the bow roller w. anti-chafe sleeve tied in place to prevent slippage.
With the endless succession of gales up here (two bouts of F10 forecast for the coming week) thoughts turn to belt and braces. If the buoy had a ring on top I would put an extra line on this, but it doesn't. Lassooing the riser doesn't seem like a good idea as if the boat sails round the mooring the two lines could twist, thereby shortening the length from riser to bow roller and putting extra tension on the riser. This has resulted in one boat I have heard of lifting its mooring on a high Spring tide and dragging it away.
The mooring is very sheltered and my conclusion is that it is best to leave the more than adequate single line and check the anti-chafe precautions regularly. However, I thought it would be interesting to hear how others do it.
Happy New Year to one and all, hope the hangovers have subsided.
- Nick
- Nick
