Karnic
I have a suzuki DF 115 A and would like to have some info re flushing using the flushing adapter under the cowl. Manual states that this should be done with engine not running. Ok. Should motor be tilted to up position or down? Also i tried this method but only left tap running for 3 minutes but only saw water going out from intake holes. Is it normal? Should this method produces also the pee stream like when running on muffs?
Thanks for your help
