Suzuki DT4 Problem
Richardson
New Member
4 Apr 2013
Hi all I have been looking around for a solution to this problem and come across the site but couldn't find anyone with a similar issue.
I got a 4hp suzuki DT4 (I think cant check as it's down the garage atm) last year and it was running fine for a few days. I believe it was put it into reverse before the revs dropped back to idle the engine still runs fine but after that It will only idle and dose not seam to select gear.
After getting home I put it in a bin and ran to to see and it kick up a little bit of water but it dose not have any power.
I will post more info tomorrow when I check that it's the correct model.
If any one has any info or could help me on this it would be much appreciated.
Thanks James
