R.F.Price
New Member
My Suzuki DF4 (2005) outboard motor jets out fuel from one of the plastic pipes attached to the top of the carb. The overflow is not constant so I assume it occurs when the float drops & the chamber fills then over fills with fuel.
I have cleaned the float chamber & needle valve with carb cleaner but the problem persists. If I blow thru the carb petrol input pipe, I can feel when the needle valve closes as I lift the float, so I assume the needle & seating is correct. My assumption then is that the float setting is incorrect, & the fuel level in the chamber is too high.
Can anyone with a workshop manual or knowledge of this engine for this engine please explain how to check & adjust the float setting, or give any other ideas how to stop the overflow.
Apart from this the engine starts & runs reasonably well.
