Bikerwookie
I have searched online for info on this one but come up with a blank.
My df2.5 appeared to overheat yesterday after over 1 hour of running. Thinking it would be the impellor I rowed back the 5 miles and stripped it. All is fine and the thermostat is working.
The tell tale has the two holes at the back of the leg and splutters out water almost in a mist. It has done this since new. When I look online at df2.5s I see videos of some tell tales producing one stream of water and others producing the mist from two holes.
Everything looks clean inside the thermostat housing with no salt build ups.
So is it ok to just produce a mist from the two hole tell tales or is the impellor not producing enough flow?
