ithet
I don't think this engine has ever been run on E10 fuel.It sounds ethanol related. These were made before the increase in ethanol was proposed, so the fuel lines are not resistant to it. The hose, tap and filter are likely to be affected and should be replaced with E10 compatible components.
Also affected is the needle valve in the carb. There may be an E10 replacement available, but the best preventative is to make sure the carb is emptied of fuel when you're not using it. Usually by turning the fuel off and letting the engine stall.
