Suzuki 2.5 Outboard Needle Valve
I want to check the condition of the float needle valve and need to remove the float pivot.
Is it a press fit or is it threaded?
It may just slide out or easily drift out as Yngmar suggests
Take care not to loose the tiny spring clip which links the needle to the float arm. #7 in this diagram
I will be dismantling tomorrow, I had cleaned the carburettor, no varnish built up, it was clean before, but I would recommend a good spray with carburettor cleaner and air gun. I had sprayed a lot of lubricant into the spark hole to unseize it. I will be stripping the engine to see what actual damage and to check if the oil pump had failed. What price did you have in mind?
