JoeQ
What's the procedure and recommended products to clean my stainless steel water tanks please?
So even when it's clean you keep some Milton in the tanks?
Perhaps I should have explained the reason for my query. I have 2 stainless steel water tanks linked at low level by a 2.5 inch diameter balance pipe that ruptured probably due to frost. Not only did it allow the tanks to empty into the bilges but it also allowed a small amount of dirty bilge water into the tanks.
The recommended dose for sterilising a tank with Milton fluid is 30ml per 5 litres. Allow to soak for 15 minutes and then rinse out.
For sterilising drinking water 2.5ml per 5 litres.
If you don't exceed this you should not have any trouble with foul tasting tea.
For a large tank 30ml/ 5litre can be quite a lot of Milton. If you therefore use bleach use a thin one which does not contain any detergents or thickeners and because it contains about 2.5 times the hypochlorite concentration as Milton use only about 12 ml/5litre.
Half a cup of bleach for 40 gallons of water, run the taps briefly to clean the pipes, leave for 8 hours then flush and fill. We had two stainless tanks and bleach caused no problems.
Between 400 and 500 cm³ ( 2 to 2½ teacupfuls ) of bleach in 40 gallons water then drain and rinse after 15 minutes would be nearer the mark.
