Sunseeker Manhattan 50 Project?
Wondered whether you would post it..... from the other photos I have seen, looks like it's located around the channel between Formentera & Ibiza, there are a lot of semi submerged rocks in that area if you don't use the cardinal marks of the main channel. P brackets & props look attached so presumably the hull was breached in a big way.
Freu Petit ? tempting short cut if you want to miss the main channel, but large semi-submerged rock there, if there's a slight chop impossible to see ... obviously not using the plotter !
There are 3 channels, Freu Grande (main channel), Freu Mediano 3m variable and Freu Chico (freu petit) very dodgy!! Personally, even with plotter, I wouldn't risk it. Probably only saving 15mins anyway
“It’s the first time that it’s happened in 20 years of chartering,” Tracey continued. “What we need to be doing around here is marking all the reefs with buoys.”
No dear, what you need to do round there is make sure you don't charter your clients' boats to complete idiots
