Sun Oddyssey Cutlass Bearing
Got mine and shaft seal for 43DS from a marine supplier in Poole will try to find name.
Edit - Lake Engineering. The shaft seal was better than the volvo one - had a air tube so dont have to burp the seal after lift out.
Does anyone know of a supplier (apart from ASAP) for the Jeanneau style cutlass bearing as Jeanneau do not supply any more?
Out of interest, do you have an issue with ones ASAP supply, as I was going to get them to supply one for my Beneteau?
The OP was enquiring about a cutlass bearing rather than a shaft seal.
I know but good info anyway as the Volvo seal is getting replaced also.
Other than the original Jeanneau bearings lasted 7 - 8 years each but the ASAP one has only lasted 3 - 4 years. The difference is the original Jeanneau are octagonal so more surface area on the shaft where as the ASAP are only hexagonal. The ones from Exaltouk are octagonal so giving them a try. Some good comments about them on the Jeanneau FB page.
Price is around the same.
My answer was plural " I got mine (by inference the cutless bearing) and the shaft seal from ....
I would not expect to replace cutless bearing on it's own.
Do you always jump down peoples throats so fast?
Now I re-read your original post I see I was mistaken. Your post makes complete sense. I have shredded my throat-jumping certificate and send my apologies.
