rob2
I have a sight glass - designed for heating fuel tank and available from BES. It needed the bottom fitting adapted to suit connection to copper fuel pipe, but has a press to open tap at the base so in the event of an engine fire, only the fuel coloumn in the tube will be released. Of course, it is only simple to install if you already have a take off from the bottom of the tank.
A similar boat to mine has a similar design concept, except that in place of a sight glass, he fitted a vertical copper pipe of suitable size to take a vertical sliding gauge - if either of these interest you, don't forget that the top of the tube must be "open", so needs a breather led to a safe height.
I'm assuming the tank is not of regular cross section as you propose filling by increments to calibrate a dipstick (same applies to a sight glass) otherwise a linear scale of increments would serve. A drill mounted pump will pump out the lot in a couple of minutes. We used a cheap plastic dustbin to temporarily store our diesel, then ladled it back in with a jug of known volume wearing marigolds unless you want to remember for a week.
Rob.
Rob.
