Suggestion p[lease: waterproof tape for leaky windows?
NealB
19 Feb 2006
Burnham on Crouch
Our old Seamaster really needs to have her windows out, refurbished, and resealed.
That's not going to happen till next year.
In the meantime, I wonder if there's a tape I could put on the outside, to stop the worst of the leaks?
Ideally, something that will do the job (of course), but be reasonably clean and easy to remove next spring.
garvellachs
23 Mar 2002
Dorset
There is 50mm waterproof clear tape from the likes of B and Q that does what it says on the tin; but I haven't left it on long term. Gaffer tape is good for proofing things if put on dry, but it leaves a residue that takes effort to remove (with WD40 or meths or similar).
Alpha22
22 Sep 2003
Cambridgeshire
The better the gaffa tape, the harder the residue is to remove.....!!! It can take hours!!!
The best stuff to look for is PVC tape. Like insulating tape, but as wide as gaffa.
prv
29 Nov 2009
Southampton
When we had water getting into the cowl of an outboard, I was pleasantly surprised to find that Gorilla Tape stuck to it readily despite being applied with wet hands in a wet boat to a wet and salty surface which had been roughly "dried" with a damp cloth. Definitely a cut above your normal grade of gaffer tape, and I don't even remember it leaving much of a residue.
emkay
1 Jun 2014
I'm in exactly the same situation, an even have through cracks in the window. I tried clear gorilla tape a few weeks ago. It works a treat, is almost invisible and has survived a good blasting with a pressure washer. Works for me, until I get time to properly fix.....
The solution for almost any repair. Sticks to smooth, rough and uneven surfaces. All the features of Gorilla Tape in a weatherproof, airtight, crystal clear version. Fix, patch, seal, hold and protect almost any surface with a crystal clear appearance. Weatherproof - water, UV and temperature resistant.
NealB
19 Feb 2006
Burnham on Crouch
Have you tried removing an yet? A quick google suggests that the residue can be very tenacious.
prv
29 Nov 2009
Southampton
Dunno about the clear kind, but the black stuff on our outboard was no problem at all. Until I fitted a new seal, we were applying and removing tape to the cowling joint each time we went out, and it always peeled off fine.
jellidreamer
4 Dec 2009
Bexleyheath
Use waterproof butyl tape,totallly waterproof and easy to remove. The stuff is so good you will never use any silicone again. Does not have a shelf life. Its so good you will keep the old windows. Hope this helps.
Alpha22
22 Sep 2003
Cambridgeshire
The stuff I used took longer to get off than the whole job of removing and re-sealing the windows!!!!!
Only time will tell..... but don't be surprised, if in a few months, the residue does not just wipe off. I tried everything on mine.... every kind of thinners and solvent..... ended up removing it mechanically..... its still took many hours.
I would think very carefully before leaving any kind of tape on my boat outside for any length of time.......
