OK - I ask on here as it's a Practical question and answer needed ...
My Garden Tractor has a sealed lead acid battery that I estimate is about 25 - 30 a/hr. Physical size is about 19cm long, 13cm deep, 16cm high. So quite compact and 12V.
Garden tractor is 13.5HP Briggs and Stratton with charge alternator fitted as well as key-start etc.
This battery is goosed after being flat during the last winter ....... it fails to hold charge and I'm stuck with long grass now !
I have a power pack with 17 a/hr Sealed Lead acid battery inside that is removeable. It is labeled with ... 14.5 - 15.0 V max charge rate initial, 13.5 - 14.0 V steady charge rate and 4.5A max rate after initial.
Pack supplies 900A peak boost, 400A start ....
Now the question is - I can buy a pack at £28 here ... and take battery out ... it is smaller than tractor job physically, but easy to fit in place of original. Original is difficult to find here and will be expensive. Will it be suitable and survive fitted to tractor ?
