Stuffing box how to pack?
Stonemonkey
20 Jul 2020
Need help to understand how to fix a leak. I’m new into sailing, owning my first boat (build in 76) for the second year. I attached a photo with what I understood is called a stuffing box. Initially I removed the tube and pumped grease into it through the nipple till it came out pushing the black seal out too. Reading on internet I understood that I need to repack the gland, but in all the materials I followed there was a nut. Any ideas on how to fix this type of box without replacing it entirety? I’m trying to avoid disconnecting the propeller shaft because that is complicated due to the rudder which staid in its way etc etc.B660CDE7-D4BB-42CA-AEFB-536ADC576CD3.jpeg
There are seals of that type that are grease lubricated rather than with oil, what is at the other end of the tube will give the answer to that; a header tank for oil, a grease cup or a screw-down reservoir for grease. The seals will be a standard size, replacements are available off the shelf.
If the lip seal has a spring fitted on the inner lip, make sure to replace the seal with one that has a STAINLESS spring fitted. That is not the default and usually has to be specified. There are also different types of rubber used in lip seals - any supplier may be able to identify the type from the old seal, or guide you on suitable materials for the application.
A PSS is a considerable expense compared with a couple of lip seals. The type owned by the OP is perfectly satisfactory with proven longevity provided the shaft is not worn and even then there are ways to overcome the problem.
True. As ever, you pay your money and make your choice. If he can fit new lip seals then it might make for a very economic repair. He might alter the length of the special rubber hose to get the lip seals to bear on a new bit of the shaft? He might also consider renewing that hose and it is worth noting that those bits of hose are NOT standard rubber hoses but ones specially made for that situation. Readily availably, but slightly more expensive than just a bit of rubber hose... eg stuffing-box-hose. other suppliers available...
