wotayottie
Or ACF-50 dissolves the corrosion products penetrates and lubricates.
The aluminium oxides formed by this sort of corrosion are totally insoluble short of strong acids and ACF 50 is basically an oil.. The OP is wasting his time with lubricants anyway. Problem is that the corrosion products are more bulky that the original metal so the further the corrosion goes, the tighter gets the joint. And to make matters worse, aluminium oxides are very grippy abrasives.
The only serious answer is heat but you can often succeed with nothing more than a kettle of boiling water ( safer than a heat gun because it wont ever go more than 100C) since ally expands so much faster than steel and hence loosens its grip quite quickly. Try that
