webcraft
Tried heating and cooling (freezing spray and mini-blowlamp) but because of the position of the plug it is impossible to really heat/cool it in isolation from the surrounding metal, most notably the engine mount.
It's right under the fuel pump and inexplicably pointing downwards so there isn't room between it and the engine mount to get anything other than an open-ended spanner on. We snapped a jaw off one 8mm spanner.
Only other options seem to be removing the fuel pump or detaching the engine mount from the engine block, slackening the bottom nut and swivelling the mount out of the way - but I am worried about disturbing the alignment with option 2.
- W
- W
