Stripping vinyl stripes
MoonDust
7 Jun 2002
I'm trying to strip tatty old vinyl stripes off the (grp) hull just above the waterline, with a view to replacing them. But they are proving hard to shift. Scraping doesn't achieve much, nor does solvent. Would moderate heat do the trick? Thanks in anticipation.
luckyjimbo
13 Feb 2002
I had this problem, I just painted over the coachlines using enamel paint, real tatty before, but came up good as new.
Regards
James
wishbone
20 Jan 2002
South Yorkshire
www.reflect-designs.co.uk
Hi I’m with Ian
We use hot air gun, then we use pre-paint to get rid of adhesive, also use pre-paint before applying new vinyl, as it doesn’t attack the paint surface! When applying new graphics use a small plastic plant spray (fine mist) filled with a mixture of meths washing up liquid and water, float on graphics and plastic squeegee off.
Good luck
Wishbone
