Boo2
Hi,
I've taken off Sunrunner's tiller to revarnish as it's got a bit tatty. My original intention was to use International Woodskin but I read on these forums that a wood stain is not really appropriate for a tiller because it is porous and that is not a good idea unless the underlying wood is an oily wood like teak. My tiller is laminated from 2 types of wood, one light coloured and one darker and reddish so I assume maybe mahogany and ash (see attached pic).
Anyway, I was thinking of applying a varnish instead and wondered if anyone can guess what was there before ? The other pic is a scraping which has an appearance akin to a thin parchment if that helps identify it. Brands of suitable replacement varnishes for this specific application would be appreciated.
I have removed all the fittings and got 2 sides done by using a scraper like this one http://www.diy.com/nav/decor/decora...rris-Pro-Long-Life-Heavyduty-Scraper-10517563 with carbide blades. It's quite hard work and it seems that once the bulk of the varnish is off the scraper takes off shavings made of 50% wood dust + 50% varnish. Will there be compatibility problems between the old and new varnish if I stop at the 50:50 stage or do I need to keep going untill absolutely all the shavings are wood dust ? And is it better to leave a scraped finish before applying the varnish or to give a rub down with sand paper first ?
Thanks,
Boo2
Thanks,
Boo2
