Tafflad
(originally posted in motor cruiser forum - advised to post here)
I fitted a Wakeboard Tower to my boat this year, or in fact the dealer did.
I'm very pleased with it.
What I intend doing out of season is laminate in some supports behind the deck fittings, to cut down on flex, and strengthen the support point.
Advice by dealer is to glue in some 3mm ply - about 60cm x 20cm, with fixing bolt through the middle.
Once glue has set, laminate in a second layer over the first.
Advised to use 3M 5200 as the adhesive.
The Q ... should I be using Marine ply for this, or as this is well above the water line, is WBP ply good enough.
Wood is used to curve to match deck shape, is 2M 5200 the right stuff to use?
