Delfini
I have a 24v domestic set of batteries which get charged from shore power or alternator and a small'ish 12v engine battery which only gets a charge when the engine is running via its separate alternator - since I took ownership of the boat last year the starter has been temperamental - sometimes it goes - sometimes it doesn’t - I have a remote starter button in the cockpit which takes its 12v power from the battery via the starter +ive terminal through various thermal and switching circuit breakers and eventually drives a relay in the engine bay which fires the solenoid - its been working OK for 3 months or so after I rewired the engine control box and replaced the starter motor and solenoid late last year - last week after doing a bit more work on the engine accessories and having changed the oil and filters etc it packed up again and given I need to move the boat this weekend I resorted to wire a starter button directly across the solenoid and postpone further investigation in the long and torturous cabling runs to and from the cockpit - the button worked OK
On Monday the engine didn’t start and after significant cursing I found myself measuring the terminal voltage across the starter - it was 6V - after a bit of mucking about with various switches (including the main isolator) and various pulling and pushing of wires it came back up to 12v and the engine started
Today I went to the boat to check all was well and the again engine didn’t show any signs of starting - I measured the starter terminal voltage and it was 1.5v - the voltage monitor on the chart table showed 2v - I checked the terminal voltage on the main 12v battery and it was 12.8V - crazy - I then mucked about with various switches and relay connections and the solenoid wiring and watched the voltage as it rose to just over 12v - again the engine started
I have persuaded myself there is something wrong with the main double pole isolating switch (which I have recently started to use when I leave the boat) since thats the only thing between the battery and the starter motor but I cant really believe any dodgy contacts or high impedance in the switching unit would result in the low voltage measurements I am seeing at the starter motor
Does anyone have experience - is it possible that the heavy duty (250A) dual pole switch could be giving me the run around - or not ?
Thanks for your feedback
