Strange thread
Graham_Wright
30 Dec 2002
Gloucestershire
www.mastaclimba.com
Five screws securing drive plate to flywheel, BMC 1.5 diesel.
26 tpi X 0.23".
I assumed it was 3/16" UNF and ordered more.
Too small, ordered 1/4" UNF too big.
Then I measured. I can't find a thread with these dimensions.
BSF is 1/4" X26 tpi is the nearest but doesn't fit.
Very unlikely to be metric but 26 tpi equals 0.97mm which could be 1mm. Diameter converts to 5.84 which could be 6mm. That doesn't fit either.
Weird.
Boater Sam
14 Mar 2020
Philippines and Thailand
I am very confused by this. Could the flywheel have been changed or redrilled?
From memory there are 6 machine screws, 1/2" AF spanner head, 5/16" UNC
But it has been a while.
Phone Calcutt Boats, they will give you a definitive answer as they rebuild these all the time.
B27
26 Jul 2023
We used to call this 'spanish pushbike thread'.
Anything that's not an obvious choice can still happen.
Coincidentally, I was tidying today and found a lot of BA spanners.
See also 'model engineer threads', basically a pitch that's easy for the lathe regardless of diameter?
Graham_Wright
30 Dec 2002
Gloucestershire
www.mastaclimba.com
I am forced to the conclusion it is metric. I found it unlikely it was metric but the gearbox is German (made in Italy!) so it is possible.
Unfortunately my extensive stock of screws went with the4 closure of my factory although the one I found was a good fit.
Graham_Wright
30 Dec 2002
Gloucestershire
www.mastaclimba.com
Those are the ones securing the flywheel to the crankshaft and they are UNF.
