Strange Nasa BM1 problem
Hi all,
to recover this post, I have check in my boat today step by step the installation and it is ok. But an extra 3A is added to charge current when I push the light in BM1.
Anyone with the same sympthom.
Regards
I think people have run out of ideas.
Maybe it is a faulty unit.
Perhaps it is time to contact Nasa for advice.
Hi All,
Perhaps will someone copy this thread and mail it to Nasa? I could do it myself ofcourse, but I feel not to much competent to explain the problem and the answer (as English is not my native language).
I have just sent the thread to NASA Marine Instruments.
I ask NASA to write the answers or news here directly or to send my by mail. If I receive something I will copu here asap.
Good look. regards
Hi,
I might have found the cause of the problem.
The negative of the two batteries have to be connected to the engine mass seperately to avoid them influencing each other the shunt is connected next to the domestic battery. Otherwise a slight difference in rest voltage ( caused by different resistance in the negative connections) will give a strong charge or discharge depending on which negative is highest.N.b.
Have a look at the picture. Its how its connected in my boat for 5 or 6 years and working great.
n.b. Only the domestic battery is measured.
Ad
http://commondatastorage.googleapis.com/static.panoramio.com/photos/original/47038702.jpg
There is one other possible fault that sometimes is overlooked.
With only one battery the alternator B+ is connected to the starter so the charging goes through the starter cable.
With two batteries and a diodesplitter or similar this connection MUST be removed and a seperate charge lead has to be connected from the alternator to the input of the splitter.
Otherwise the + of both batteries will stay connected what makes the splitter obselete.
This can be seen e.g. on
http://www.vetusweb.com/manuals/fil...itters_-_Inverters_-_etc/090305 r03 01-03.pdf
Especially when a second battery is installed later this fault is often made.
Ad
Thanks lula.
Update from me: I have checked and double checked and changed everything according to the advice given in this thread. I checked and measured the black and white wires. Everything as it should be.
There still remains about 2A difference between backlight off (higher dicharge)and on (lower discharge). The values as given with the backlight on seems the right values, so there is no possibility to use the offset and get an avarage value.
Furthermore I noticed that the BM-1 measures a voltage of the battery during discharging (lamps on) and shows quite a big drop in voltage and capacity. These values are the same as measured directly on the battery with a multimeter, but shouldn't the bm-1 show the 'real' capacity as shown when the battery is at rest?
It will be interesting to see what Nasa have to say.
As far as I can see, having given this some more thought, the only thing that will give a false, or increased charge reading when the back light is turned on is a poor connection between the white and black wires and the shunt.
A poor connection there will also give a reduced reading for the battery volts when the back light is turned on but poor connections on the positive (red) connection or the fuse would also do that.
The voltage between the black and white wires reported earlier in the thread indicates a poor connection between the white and black wires within the crimp .... If the connection was good there would not, could not, be a voltage between the two!
Personally I would either solder the black and white wires into the crimp or cut off the crimp and simply solder the two together and then make doubly, trebly certain that there was a 100% good connection with the shunt.
I would check for any voltage between the battery connection and the black and white wires when the back light is on... there should be none!
Just to be sure:
Next weekend I will remove the crimp and solder black and white together on the shunt side.
Thanks for all the help!
It's what I would do. Others do not approve of soldering connections on boat installations.
Good look. regards
NASA answer follows
Dear Sir,
After reading the thread it appears you have been given some good advice: The backlight draws about 10mA. This current is supplied through the red wire and returned back to the battery through the black wire. If the black wire is not properly connected then the return will pass through the white wire which is one of the shunt sense wires. It only takes 50mV accross the sense wires for the display to read 100A. So even a few mA throughthe sense wire will cause a problem.Check all the connections. Make sure the terminal screws are tight and on the wire rather than the plastic sleeve. The offset is caused by stray voltages generated in the sense wire(white and yellow wires) terminals and should never be more than 0.1 to 0.2 Amp. It can, of course be ballanced out but if it's as high as 2amp then there is something wrong and ballancing it out should not be attempted. If you can't sort the issue recommend you reyurn the unit to us for test.
Regards,
NASA Marine
Boulton Road
Stevenage
Herts
SG1 4QG
Hi,
I'm afraid I made some mistakes in my post on this thread yesterday at 14:59
I looked at the wrong picture but now I deleted it.
So have another look at it.
Ad
Hi,
Ad
I had a second look at your post, as you requested.
There's no need to connect the negatives separately to the engine, as long as the cables are properly sized and securely connected. It won't make any difference to the current in the domestic circuit.
Your diagram shows the negative connection of the charge splitter going to the battery side of the BM1 shunt. For correct operation, the only wires on the battery side of the shunt should be the battery negative cable and the black & white sense wires for the BM1. Some charge split devices (eg VSRs) draw a constant small current, so should be correctly connected to ensure the BM1 results are accurate.
You're correct about that.
I zero'd it when installing the BM1 but may be I'll change it.
About the negative wires. Of course when the wires are thick enough this is the same as directly on the engine. Its just that I did because that was the easyest way for me.
Ad
OK, but it's important to realise that some people could have thought that your statement "The negative of the two batteries have to be connected to the engine mass seperately to avoid them influencing each other" was true. That's how a lot of confusion creeps in to these forums.
NASA answer follows
Dear Sir,
Regards,
NASA Marine
Boulton Road
Stevenage
Herts
SG1 4QG
Well they have not come up with anything new. Not sure whether to be disappointed or pleased that the might of the forum has thought of everything.
Back to checking and rechecking that all the connections are good.
They have told us that the backlight takes approx 10mA so to produce a discrepancy of 3 amps on the display it only needs a resistance of 0.15 ohms in the wrong place. That is very small!
Very unusual thread, since all the advice freely given seems to have taken some time to sink in.
Maine Sail, a contributor to this board in the past, has posted this helpful thread:
http://forums.catalina.sailboatowners.com/showthread.php?p=777665&highlight=battery monitor
It's really not so hard to follow directions, manuals and advice. Shunts are pretty tricky. I made this article, too. which links back to Maine Sail's: http://c34.org/bbs/index.php/topic,6032.0.html
Good luck. I agree wholeheartedly with Vic's and others' advice. And even the manufacturer says so.:)
Today I renewed the black-white socket.
Nothing changed!
Still a voltage shown of 0,3
When I disconnect the red wire (just to see if there is some interference with another equipment close to the wiring or so): there is no voltage to be measured.
The only thing that might be checked would be a complete new wiring I suppose.
The red wire is the positive power supply to the BM1 when it is disconnected the thing should go completely dead. No display, no backlight .. nothing.
I'd experiment with disconnecting the white and the yellow wires. With either disconnected you should not get any current reading. I am not sure if disconnecting them, either or both, will kill the volts reading but the instrument should not go dead with them both disconnected.
Are you still getting a voltage difference between the black and the white wires when the back light is on as you were in post #14? If you are then finding out why is the key to the problem I am sure.
Nothing changed!
Peiter, how did you 'renew' the black- white connection? If you are still measuring 0.3V between black and white then the connection is still faulty. It should be zero.
Disconnecting the red removes 'power' from the meter, which is therefore effectively turned off.
I totally renewed the crimp of the connector of the black and white wire at place of the shunt.
Putting off the red wire: no voltage difference
Putting on the red wire: again 0,3 V on the black and white. At the BM-1 dispaly I still have the difference in reading the Amp (1,9 A with backlight off / 0,1 with backlight on)
So, the only thing I can come up with is that the black or white wire might be damaged or faulty in some other way.
I will rewire the black and white totally.
If that does not help I will return the BM-1 to NASA (or the fishes).
I don't see what the yellow wire could do for this.
