Thallac
I am not sure if you will be able to help as I have a strange electrical fault.
The problem is that after running the engine for 30 minutes the starboard power goes off making my gps flicker off and my vhf say lo battery. I then switch over to the port battery bank and the power comes back on. Then back to starboard battery pack and the power works okay for another 30 minutes, then the same problem starts ago.
I thought it was the battery isolator being faulty so have changed this, but it still persists.
The engine starts okay.
I have not tested the battery or alternator as not sure how to. Not sure how it can be the alternator as the batteries do not seem falt
The set up I have is
Port one battery for port engine
Starboard two batteries for sb engine and boat electrics.
Any suggestions. Hope you can help
