Stowe Depth NavSounder - repeater output format?
pagoda
19 May 2008
Scotland
This is one for the serious tinkerers.
Has anybody got any ideas about the data format used between Stowe Navsounder and the Repeater instrument for same. It involves just 2 wires, so my current suspicion is a simple serial format, maybe an early form of NMEA?
I could spend a couple of days with an oscilliscope, but should anybody else have cracked the format that would take some of the pain out. I was thinking of actively logging depth along with GPS data, using some spare instruments I have, and Arduino to process the numbers. Mixture of antique & modern YAPP :p
I know you can buy transducers which spit out DBT words ,but I don't want to spend that kind of money :D ..effort maybe , wads of cash.. no!
thanks in advance,
Graeme
NavSounders with serial number 4000 onwards take a repeater wired to all the terminals as shown n the manual - not just two wires.
PM me if you need the manual.
Sorry if that didn't answer your question.
Thanks,
I can't recall what the serial no is, but the "repeater" terminals on the back are marked "blue & white" - the other common connections are just power & lighting. So only 2 wires are involved in transmitting the depth value to the other display. That's the format I want to "crack". I'll maybe just pull the case off and find what chip is connected to those 2 wires. And use the scope.
It's got to be simple, even if it's 100 pulses =10.0m or something like that?
I quite like the idea of collecting bottom information of specific anchorages I use and building a library of more detailed bathymmetry over time? Boat position is not too difficult -I can log NMEA GPS data. I have a realtime clock module - so I can back out tidal differences form readings. I just want to decode the repeater output to acquire the depth values and insert them into the position stream, or in parallel at least.
I have a spare instrument and transducer, so if I can get this working -I can use it on the dinghy to grid out interesting but poorly documented approaches or anchoring spots, then generate a simple small area chart..
More systematic than doing sketches, and marking down ugly looking patches of weed/rock and scary moments of minimal clearance with a keel. I'd sketch things anyway.
I really didn't expect anybody to have tried this, but you never know!
Graeme
On the East coast a lot of work is done by Tillergirl. Look at the downloads on his website Crossing the Thames Estuary.
I've just had a look at that East Coast Sailing info. Very nicely presented. That's the sort of thing I fancy doing, but for various places on the Scottish West coast. I see a steep learning curve getting up to that standard :)
Graeme
