MainlySteam
I go along with a high modulus rope luff line attached to a similar material halyard as being sufficient and is probably the way I would go if I did it again.
Looking at it from the reverse viewpoint we have a permanent inner wire forestay to the second (upper) spreaders for setting small and storm jibs but it is not set up as drum tight when unused because even on a heavily rigged cruising vessel it will set the mast forward at the upper spreaders. The reverse bit is that when in use it is pulled up tight with high modulus rope, not wire, runners taken aft.
I suspect that if a rope runner (and rope running backstays are very common) can pull a wire forestay tight then a high modulus rope luff line and halyard on a jib can be tightened enough and without problem by whatever means the rig makes available.
It also does away with the maintenance and the rigging time of hanks (including avoiding finding that one has hanked one round back to front when go to hoist /forums/images/icons/blush.gif).
John
John
