CalicoJack
We had exactly the same problem with that set up. When we brought the boat we found that the gearbox (TMP)was very noisy and needed a bearing replaced. The manufacturers, yes they are still going, said that the wear had been caused by the prop auto rotating whilst sailing, which deprived the bearings in the top of the box of oil. Their suggestion was to start the engine every hour or so, & let it run for a couple of minutes so as to circulate the oil. This also had the benefit of passing water through the stern tube. Despite that we fitted a Kiwi prop which has improved things, although we still get some auto rotation when sailing above 6 it's.
