PotatoNavigator
My boat is due to come out of the water soon and one of my jobs is to attempt to reduce the vibration noise caused by the outboard. It is unbearable after more than about 10 minutes, to the point where it ruins a trip if the wind dies and we have to motor sail.
I have a Tohatsu sailpro 6hp which sits in a well. The problem doesn't lie with the outboard itself (I put it on a dinghy once and it was near silent), but with the cockpit sole and seats. The construction means that the entire cockpit is essentially floating, only connecting to anything else at the companionway and the gunwales.
The mount for the engine is part of the same construction as the well, so the aft facing portion does connect to the hull, but only over a width of about a foot, since either side of the well are two lockers which connect to each other under the cockpit, in front of the well.
You might get a better idea of the design here:
http://sailboatdata.com/viewrecord.asp?class_id=3978
My current idea is to wedge rods with rubber feet on the ends between the hull and cockpit floor to dampen the vibration. Before I start a series of time wasting exercises does anyone have experience with anything similar, or any better ideas?
// Mounting the engine on a bracket off the stern is not an option, since the position of the lockers would make it impossible to control. Also fitting an inboard is out, partly due to cost and partly due to there not being enough room. It was an option specified when the boats were originally built, but the space only allowed for a lawnmower engine type set up, which will hardly improve my noise situation.
