Leighb
The stop solenoid on our port engine stopped functioning while we were away on holiday so had to stop it manually, no big deal but it means lifting a floorboard in the wheelhouse.
It had been intermittent earlier in the year, but the engineer said it was "sticky" and he had sorted it.
I am unsure if the problem is with the solenoid itself or with the wiring or the switch.
I connected my multimeter with Pos to the terminal on the solenoid and Neg to the engine . Then with engine switch ON tried pressing the Stop button, expecting to see a voltage on the meter, but not a flicker.
Does this mean there is no supply to the solenoid, or have I got my connections all wrong? I wondered if perhaps it could only be energised when the engine was running? Looking at the wiring diagram it appears not to be the case.
Can anyone enlighten me please?
If the solenoid needs to be removed, is that straightforward? The parts diagram seems to show a spring beneath it, and I am concerned that something might leap out and be difficult/impossible to refit correctly.
