Stinking water tank.
lockwood
19 Dec 2004
Cardiff
www.craiglockwood.co.uk
I have never used the water tanks on my 1977 Jaguar 22 as it is stinking - crawlies and nasties live there.
There doesn't seem to be a drainage tap at the bottom, so the only access I have is through the top water inlet. Therefore, flushing the system takes hours of sweating at a pump.
What is the best thing to clean the tank?
Mudplugger
12 Jun 2003
East Coast/ North Sea
Lots of threads on this in the past...can't remember the dilution rates for Bleach.... but alway's had success with Milton. followed the destructions and leave for 24hrs, drain & refill...
VicS
13 Jul 2002
Re: No more debates about bleach and Milton
Please Please Please No more debates about domestic bleach versus Milton versus proprietary tank cleaners.
Please Please Please do a search and read what has been said many times before.
TigaWave
17 Dec 2004
Buckland Monachorum
www.H4marine.com
Whilst you're at it cut a hole in the top and fit an inspection hatch, then you can get your arm in and give it a good scrub in th corners, where its sure to be green. Just a circle 7-8" diameter should do.
graham
If you dont want to read it why click on it? agree that a search is a good idea but do you do a search before every posting you do ?personally I couldnt be arsed .
Re the tank, if its that bad is it possible to fit a liner by cutting a hole as previously suggested then if normal cleaning ,bleach milton or whatever wont do it, you could fit a flexible tank inside the old one.
pvb
UK East Coast
Quite right...
Let's not debate it, just do a search, and discover that ordinary household bleach is the right stuff to use to kill off the nasties in the tank quickly and cheaply. Rinse it through a few times and you won't die from drinking the water.
wooslehunter
31 Oct 2002
Hants, UK
Re: Quite right...
Inspection hole is a must. Use a round dinghy type hatch.
To pump out fast I use an electric drill pump. You can get them for about £10 from Machine Mart. Pumps fast with a mains drill & works OK from a cordless.
Alternatively a manual bilge pump mounted on a piece of ply is always a useful thing to have around.
